Try this one;
Engine Oil Temperature (Degrees F)
TXD: 07E02103
RXF: 032500000000
RXD: 3008
MTH: 01B0014FFCA
NAM: EOT
Transmission Oil Temperature (Degrees F)
TXD: 07E021A0
RXF: 032500000000
RXD: 2008
MTH: 00090005FFD8
NAM: TFT
OBD2 Mode and PID (in hex - eg: '01 0D' for speed) or empty if '[internal_pid]' is used in the equation: 07E02103 ? (this gives me an error: 'PID is too long - can be 3 bytes (6 hex characters only) The Generic PID for Engine Oil Temp is: 01 5C
Long name: Engine Oil Temperature
Short Name: EOT
Minimum Value: 0
Maximum Value: 200
Scale Factor: x1
Unit type: (degree symbol) F
Equation (eg: A * B + 20 or [0d]+10+A or even just [0d]: ? ((A*256)+B)*100*(9/5)-4001
OBD Header to use (Leave blank, 'Auto' or HEX header) ? Leave blank.
Gave these ones a try. No success. Always getting the "No Response" Message.
There's also a Hyundai add on for Torque Pro called ; Hyundai Adv
Advanced EX for HYUNDAI - Apps on Google Play
Monitor specific HYUNDAI parameters by adding this plugin to Torque Pro.play.google.comAdvanced LT for HYUNDAI - Apps on Google Play
Monitor specific HYUNDAI parameters by adding this plugin to Torque Pro.play.google.comTorque Pro Forum;Plugins - Torque Wiki
torque-bhp.com
Forums — » Torque OBD ECU Scanner » Torque Discussion / IdeasTorque
I will not try the Hyundai Plugins. These seem to be a waste of money as they are out of date and lack proper support for the modern vehicles. Seems both plugins have been abandoned since 2015 :/
Will take a look at the Torque forum, maybe someone came up with something...
