@BurntRice
Sorry , it was tricky to explain.
Lets compare to what i had before ( a VW set) to set the scene.
Before, the jack and winding handle are together, part of the same tool. When you place the jack into the foam holder, the handle is on its side, like your right arm next to your torso, say. The wheel nut brace is a separate item of course.
The Hyundai set however, the jack ( which i am ok with) is separated to the winding handle ( the rod with the hook), and annoyingly, i need the brace as well to wind the jack.
I tend to jack it up a little, loosen the nuts , then jack up it all the way, and then unscrew further until all the nuts are off.
As there is no other tools to removes the nuts ( VW had a screwdriver where the plastic handle had a female recess to to unscrew the nuts), i had to use the brace, back to the jack, then back to the nuts, then back to the jack.
with the VW tools, i used to jack up the car with my right hand and unscrew the nut with my left, after they were loosened.
The Hyundai brace and jack handle is awkward to use as well, so i bought one of these from ebay
i guess i should stop moaning and get a cordless wheel gun!
