How-To: Remove wing mirror covers
loafer-N77
1,744
2,305
***Warning: this is a bit of a pig of a job and no responsibility for any damage from this How-To if you break anything......blah, blah, blah etc.***
For the purpose of producing this guide I already had a damaged drivers side assembly to work with. I fully recommend you remove the whole assembly from the car to try and remove the cover/cap. Luckily a handsome hero has done a How-To for that as well..........see here: How to remove wing mirror
Tools needed.
Screwdrivers: Small flat and posi head
Trim tools (Smaller the better and as many as you can get your hands on)
Step 1 - (Remove mirror glass)
No pics for this step, sorry. But all you need to do is prise the glass carefully up and away from the housing. Use a Trim tool and if you can, get your fingers under the glass and try and spread the force as best you can. It will pop out fairly easily.
Unplug both wires and make a note of their orientation!
Set glass carefully aside.
You will be left with this:
Step 2 - Remove actuator assembly
Remove the long small posi screw from the centre of the assembly as shown below:
Spaced around the actuator base are 3 (or 4) clip positions. You just need to work on one, using a small screwdriver push the clip outwards and with your other hand 'pop' the actuator out. See below for clip position:
Unplug the actuator and set safely aside.
Step 3 - Removal of cap/cover
Now everything is out the way we are now in a position to work on the cover. After removing the glass and actuator we have access to the one clip position we need to release to get the cover off.
See pic below:
Use a trim tool and give this little fella a careful push and this will release the cover portion on the outside by the side repeater.
USING GREAT CARE! Get your trim removal tools and start to release the cover on the outside edges. Take your time and be careful.
Use as many trim tools as you can (at least 3-4), once you've released one part of the cover, stick a trim tool in there and continue around the cover.
Like so:
Eventually the cover will pop off (quite violently so watch out).
TAKE CARE! (have I mentioned that........šŸ˜„)
By this point I was getting the hump with the whole process and as it was a spare unit I went in a bit too heavy handed and broke one the clips on the cover
It has no detrimental effect and the cover goes back on with zero issues, but hey not ideal.
Here are some disassembled pics:
Assembly is the opposite of the disassembly. Getting the cover back on can take a few goes, be careful (again) and make sure everything is lined up. It takes a bit of force and 'snaps' in tightly.
Kudos to Hyundai for making a stupidly over-engineered wing mirror assembly!
THE END
after trying this method last night to remove my mirror caps ended up breaking the glass on the first one as its so stuck in there. anyway when doing the other side we found out that you can access the clip needed to remove the cap without removing the glass or the actuator but you just need to be at the correct angle and have the correct sort of screwdriver or tool to ping the clip.
We did how ever on both sides break that same clip as mentioned above and that was using many tools too. I can confirm this doesn't really affect the caps going back on.
Reactions: loafer-N77
Thanks for the feedback. Tbh removal of glass and actuator was purely for ease of access.
I thought they were so easy to remove that you may as well.......that was seriously bad luck breaking the glass!! Mine popped out easy and have done with every other of my previous cars I've tried that on.
Well i was lucky enough to find a company who supplied an aftermarket glass to OEM spec for only £21.95 including next day delivery. Compared to the price Hyundai want at £118.38+VAT. Ive tested it all apart from the heating part has all the connectors so should be all ok.
Bargain.
(Hyundai UK must be on crack with some of their pricings for basic parts!!)
Does anyone remember the orientation of the connectors on the driver's side? (Right hand) I'm certain it was the red stripe wire to the outside of the car and the solid black towards the inside of the car. But 2nd guessing myself.
Thanks,
Bonics
Reactions: bonics96
Nah sorry bad explaination my bad, the connectors behind the glass for the heated mirror, I've since realised that heating elements don't require a polarity so it's a non issue
Bonics
It happened to me last week, backing into the garage knowing I want to do some work on the brakes, I reversed too near the nearside and damaged the edge of the mirror surround, checked prices, dealer wanted £460.00 plus VAT . Part number is 87610S0120 LH and 87620S0120 RH. Even the scrappies wanted £130 minimum and another said £285 plus VAT for an N one.
I didn't fancy that so I found an ebay seller that had new ones for £169.00 Inc VAT, I offered £150 and got it with free delivery.
The plan was to strip the mirror and remove the bit I wanted which is 87615B in the pic, the reasoning behind this is that the replacement only had about 4 of the wires in the main connector pinned whereas mine was fully populated with 16 wires. Plus the colour was a really nice gray but not piano black like mine.
To continue taking it apart was fairly easy, no clips broken removing the painted cover but I went round the lower edge until it was unclipped by sliding a trim tool from the indicator end all the way along the lower edge. The was a total of 8 screws to remove to split the parts plus 3 under a cover in the mirror hinge area.
Anyway it's all apart and next chance I get I will remove my one, strip it and swap the parts over. I'll let you know how I get on. There was also a useful You Tube video on removing the indicator as there's a screw underneath it. I've attached some pics and will post the re assembly if anyone is interested?
Well the swap went ok, it took just over an hours to strip the original mirror and replace that broken surround. That lower clip on the mirror cover broke for me as well, I used JB Weld to secure it back on.
Reactions: p_b82 and RossTi30N
Jist to add an observation, the mirror cover (gloss black part) clips need a different method to release to avoid breaking the middle lower clip. The first clip can be released from the inside of the mirror assy as explained in the OP pictures, once that is out go to the indictator side and start levering at the top of the released part, not the bottom, the remaining clips needs downward pressure, not upwards. This will prevent the middle clips demise.
Reactions: Hades
Maybe a stupid question, but does anyone facing issues, that the left mirror drives all the way down without stopping while parking? It seems like the teached position is not found anymore. Is there a way to reset the ACTUATOR ASSY?
Or should i buy a new one and switch both?
Disconnect the battery for a few minutes. While disconnected touch the live and earth cables together for a few seconds to discharge all residual power and then reconnect the battery.
Reactions: Marcuswayne
