Yes.May I ask why?
Fishing Line 15 lbs. or less or dental floss, WD-40 to loosen the 3M strip from the underside of the Shark Fin and the body. Take your time and work back and forth with the line, until it's loose all the way around. Once you get it free from the body, there will be a small nut and wire connected to the antenna mount and the shark fin to remove. Voila' you're finished.
May I ask why?
Thanks, got it. What you wrapping it with mate?Yes.
Roof wrap.
Thanks. Hmmmm tape huh?? Interesting. Do you happen to know if there are any indicators that'll aid in centring when I need to reinstall? ie notches or guides? Would like to know more before I get under there only to be surprised with more work than it's worth.
Ideally the removal of antenna for my little project would be best. Plan B would be to work the rubber seal at the base. Rubber doesn't seen forgiving and has more high tension.
