How To: Rear Spoiler Disassembly
padigree
Apr 1, 2018
1,690
2,889
www.youtube.com
In this Short Video I Show you how to remove your rear Spoiler.
Why should I do that? Reasons:
- You want to the triangle (replacement, conversion, tinting), which can only be removed if the spoiler is dismantled.
- You want a retrofit spoiler.
- You want to see the rear window sprayer
Time required depending on skill for disassembly and assembly 15-30 min.
Required tools: Small squeaky box is sufficient. 8mm + 10mm nut
If you want to disassemble the spoiler to expand the triangle you also need a PH2 screwdriver.
