If anyone wants to use LEDs with no resistors integrated (I strongly believe their lifespan is limited due to very tight packaging and overheating) - you can install resistors.
There's plenty of space behind the boot trim, you just need to remove a couple of screws to access the area on each side.
You can mount the resistors right against the car body to ensure cooler operating temps.
I've tested these for a couple of minutes, they get quite warm.
The resistors should be connected in parallel on grey and black wires of the indicator/stoplight connector.
I used these:
Buy PHILIPS LED CANBUS 21W 12V RESISTOR warning canceller LED car lamp 18957X2 Set of 2 at Amazon UK. Free delivery on eligible orders.
www.amazon.co.uk
Couple of pics of where these get installed.
View attachment 14872View attachment 14873
