Because I have been asked it serval times, I will make a how to topic here.
Step 1:
Turn your left wheel in and you have an access to 3 plastic clips inside of front fender. Use flat head screwdriver or plastic trim removal tool. Remove 2 lower clips and one clip above cut-in hole.
Step 2:
Take 8mm socket and remove the bolt located inside of rectangular-shape hole of fender flare:
Step 3:
Repeat Step 1 and 2 on another side of car.
Step 4:
Open the bonnet and remove 6-plastic clips shown on picture:
Step 5:
Remove 7 platsic clips under front bumper and by using 10mm socket, remove 4 bolts from bottom cover plate:
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
