Ok ill check that too while I have everything else open to replace the pump so might as well check it and the plugs too. I always use 91 or better since I have access to both, maybe I'll step up and go back to using a cleaner on a regular basis. ThanksI used to very occasionally have this problem and it sounds like the starter motor intervening because the revs were so low initially after starting. I suspected injector problems, so I used a few bottles of Forte injector cleaner which cured it immediately. I now regularly use super unleaded. Never had the issue again. Amazon sell the Forte injector cleaner.
