Are you running a 24mm Front Bar?Yes I have.
Nope, takes a little maneuvering to get out but will do so, without either. Suggest you utilize a hydraulic lift somewhere. it's not really a job for ramps. It can be done but be ready to bust some fingers.
Do you get any knocking noises coming from your rear bar ? Got a horrendous knocking noise coming from my rear 24mm bar. Thanks.24mm front and 24mm rear Whiteline. I didn't feel any change in the actual ride but you have to remember, I'm using a Mando ECS 10 suspension tuner. I can change the ride quite drastically, so ride to me is relative.
Turn in was much quicker and traction is noticeable better. I don't get any body roll as with the OEM sway bar and there's literally no effort in steering. It might be a bit more twitchy but in a good way.
I have the springs to install but I'm making changes progressively. I may not utilize them but I'll see as the newness wears off.
I'm also using Whiteline KLC180-295 adjustable end links and Anti-Lift/Caster Bushing Kit.
https://www.genracer.com/whiteline-front-24mm-sway-bar-for-2019-hyundai-veloster-n/
View attachment 10015View attachment 10016View attachment 10018View attachment 10019
No none whatsoever.Do you get any knocking noises coming from your rear bar ? Got a horrendous knocking noise coming from my rear 24mm bar. Thanks.
I assume that the car's big difference is in the positive way - for daily/sporty regular roads?I have also both front and rear ARB-s installed together with Whiteline drop links and their front anti lift kit. I am using ST XTA coilover suspension and Whiteline kit makes remarkable changes on the track. On normal roads more beefy ARB-s does not make much changes but if you will also install Whiteline anti lift kit, there will be also big difference on regular roads.
Just to confirm you can install the front anti roll bar without dropping the sub frame??Yes I have.
Base: 23mm frontWhat is the size of the oem ARBs?
Just looking at it, it's possible with the right sockets, extensions and swivel ends. There's enough space to pull the bar out without dropping the subframe and the real challenge would be getting a socket on 2 of the bolts that sit right under the steering rack. Just keep in mind this is just for the Veloster N. I have no idea how it is for the i30Ns.Just to confirm you can install the front anti roll bar without dropping the sub frame??
Cheers
