Exhaust valve
Oct 2, 2018
49
12
Portugal
Hello guys!
I have noticed that my exhaust valve after the cold start lowers the RPM the valve does not open immediately, remains closed and only opens after a while. In a normal situation it would open as soon as the RPM decrease to 1000k.
Is it a issue or does it have to do with low temperatures? I'm from Portugal and here it's been 11 degrees more or less...
Onibas96
21
17
Portugal
Ty both! I was worried if this was an issue 😅 I have the car since 2018 and I didn't discover everything in 2 years, shame on me 🤦
Mine rattles on the exhaust valve, nut only in "not N" modes, dealer says it's normal.
But i've checked everywhere and it's not normal,its the spring that's getting weak.
Does anyone have a way to find the spring in Europe?
Reactions: loboo
NULLOBANDITO
1,667
2,264
Innsbruck, Austria
Kristian
26
19
England
Does anyone know if this is available from a UK based seller?
Alternatively does the linked site have an English option?
5,022
ASR Component GmbH
  1. Home page
  2. Stiff clutch spring (Küster)
STIFF CLUTCH SPRING (KÜSTER)
15.00 €
including VAT plus shipping costs
Stiff clutch spring for servomotors from Küster
Quantity discount
quantityDiscountYou save
23.00 €Up to € 6.00
quantity
IN THE CART
Item can be ordered, shipping time 1-14 working days
Stiff clutch spring for servomotors from Küster.
With this coupling it is possible to prevent unsightly noises from the exhaust flaps. Due to the higher stiffness compared to the standard spring, the flap is closed with a higher force, which can lead to the avoidance of noises.
The clutch spring is replaced 1: 1 by the original.
Please check the images for comparison.
COMPANIES
CONTACT
ASR Component GmbH
Im Hof 24
51503 Rösrath
Call us: +49 2245 6191488 / info@asr-component.de
E-Mail: info@asr-component.de
YOUR ACCOUNT
Reactions: Kristian and loboo
Bu11eT
1,474
2,190
Germany · Schleswig-Holstein
check for VWAG tuning pages if you can get the spring there. If I recall correctly the spring is the same as Hyundai utilizes the same valve control motor unit as VW uses in their cars as well.
Reactions: loafer-N77
