There is a plethora of reasons for the issue. Everything from a bad boot, spark plug to software reflashing. It's a matter of diagnosing the problem correctly. There is not one fix for all.
If it's the spark plug boots clean them and use some dielectric grease.
If it's the coil pack, swap one out till you find the bad one or check it's capacity.
If it's ECU software, take it in and ask for the software to be reflashed.
The list goes on and on, most of which has been discussed here at one time or another .
