Electric seat 'set' button
Thirdway
14
11
U.K.
I accidentally pressed the set button today whilst giving the interior a bit of a clean. Seat went into full recline. Ignition was off, key was out of car. This time it didn't jam-phew, but I don't know why it should do that. Anyone else had that happen, or can give it a try to see if it happens to their car ?
3,435
Was the seat reset completely or set to a specific adjustment? You might want to combine this occurrence with the other thread you started.
It will definately help you and others find a common occurrence or issue much quicker. It will also be a compilation of present events.
Thirdway
14
11
U.K.
Cheer Veloster,
to clarify. The instructions for setting up for driver 1 or 2 are to position the seat, press 1 or 2, the dash then tells you to press 'set' to confirm the selection within 3 seconds. I would have thought pressing the set button on its own wouldn't do anything. Pressing 1 or 2 moves the seat to the preset conditions selected for each driver. Pressing the set button without going through any sequence puts the seat into a random position of fully reclined.
Davo01
404
513
South Australia
Just tested my i30N.
Pressing set does nothing except ask you to push position 1 or 2 to save the seat position. This only occurs with key in the car.
It does nothing at all with key out of the car with the door open or closed.
All the above is as expected/described in tbe manual.
Yours seems odd indeed.
_Emma
1,241
1,343
Stupid question but are you sure you didn’t press position 2? That would move the seat like that
Reactions: Davo01
Thirdway
14
11
U.K.
Yes, something is definitely odd. I shall endeavour not to accidentally touch it until the first service.
Reactions: Davo01
