Engine Don’t do BPV-to-BOV mod
Y0UKN0WITSCHRIS
1,058
1,025
Just wanted to post this before people start doing it and running into the same issue I did. A popular mod on the VT was to pull off the recirculating line coming off the intercooler recir valve which would result in a poor mans BOV. However after attempting this today I found it does NOTHING. For some reason the factory recir valve on the VN is super quiet and even under full boost you get a tiny amount of noise but IMO not enough to justify doing this. Just leave this alone and purchase a proper BOV when they start becoming available. Picture posted below is just for reference Incase anyone’s unfamiliar with the topic.
Y0UKN0WITSCHRIS
1,058
1,025
Also forgot to mention while trying to do this today I found the clamp that holds the intake tube to the air box was loose. Which explains the whistling noise I had been hearing when do full throttle pulls.
1FastStagea
493
765
Canada
Come on Chris, I thought you'd know better than this... lmao.
The lack of noise should be the least of your worries with this "mod", I'd be more concerned with all the hot, unfiltered air bypassing the air filter with the recirc valve hose disconnected.
Y0UKN0WITSCHRIS
1,058
1,025
Well that was also my other concern as well.But my VT recirc tube had a ton of moisture/oil residue built up in it and this one’s bone dry. Did you ever disconnect yours ? But What irked me is the fact that my intake pipe wasn’t on all the way and I’ve driven 1k miles with the engine sucking in God knows what since it wasn’t properly seated on the filter housing.
Cygnus X-1
1,172
1,546
US
Good. It will force owners to get a proper valve if they want blowoff sounds. You wouldn’t believe the number of VT owners that have asked about capping the outlet tube or putting a filter on the end of it. o_O
Y0UKN0WITSCHRIS
1,058
1,025
I remember seeing all those fools putting pvc filters in the recir vent hose.. then wondering why they have turbo flutter o_O
