Does the car save custom modes?
If you set the parameters in N custom, can you save that combination? If so how many combinations can you save? Or if you are in N Custom and switch to normal or shut the car off, does the car go back to the last custom parameters you had selected?
#2
As far as I'm aware (I've only had the car a few days) you can only have one combination of settings in N Custom mode. It defaults back to Normal mode when you turn off the ignition but as soon as you select N Custom again, it goes back to the last configuration that you set.
Edit: Oops. Just seen which section this was posted in. I'm talking about the i30N Hatchback.
#3
Thanks, it's probably the same system on both cars. It would be nice to be able save maps for autocross, snow, crummy potholed commute, etc... I'm at the calling dealers stage and I have not found one who knows much of anything about the car.
#4
I doubt you'll find a dealer that knows anything. It does indeed save the N Custom settings. You have only one custom mode so only one cofiguration. I'd prefer if there were atleast two but I've learned to live with it. I drive mostly in normal and switch to N Custom when I want to be N-aughty. N mode is a big no no because of the insanely stiff suspension. I've got Custom set to everything in Sport+ and suspension in Normal. I find Eco and Sport to be useless. Rev matching doesn't work in Eco and the exhaust isn't fully open in Sport.
After you've driven the car a few days, you'll find what's the best configuration for you :)
