Suspension and Chassis DCT camber bolts on a manual?
jm1681
7
Phoenix AZ
Was watching this video and at the 1:35 mark, the narrator explains that the DCT N has -1.6 degrees front camber, versus -0.6 degrees in the manual.
This being the case, how do we feel about possibly running DCT camber bolts in a manual car? If the suspension and geometry is otherwise the same, save for the bolts, seems like a logical move.
Just thinking out loud.
5,023
Camber Bolts are available for the manual and have been for a year or so. They can be purchased from several companies. I utilize them and will continue to do so with the Forge Motorsport Top Mounts. These particular SPC camber bolts give 1.75 in both directions
For the DCT, the extra weight is the additional factor for the increase in camber. It weighs 134 lbs more, than the manual. :)
Nomad17
352
307
USA
Haven't confirmed this but previously I thought I saw that the front track was wider as well, necessary to fit the dct? Maybe the camber is necessary to clear bodywork at the top of suspension travel.
5,023
Why would anyone possibly want to pay dealership prices, for a part that is widely available in the aftermarket?
There's no question of warranty issues. So there is no advantage of paying triple the cost for a OEM part that is not as well manufactured. Just my personal thoughts. Camber bolts are an inexpensive part to purchase and swap out.
Also keep in mind, they may not have utilized camber bolts to achieve the increase in camber. It maybe due to a completely different modified part for the suspension. They have not stated how it was achieved. :)
Reactions: jm1681
jm1681
7
Phoenix AZ
Honestly? I've been surprised enough times at a part NOT costing a lot at a dealership, that if it's an option to get an OEM part, I'd rather go that route if it gets the same job done.
In the scheme of things, like we've all said, we don't know at this point where the change comes from in the new front end. If it were down to a non-adjustable factory bolt, that ultimately dialed camber to a desirable setting, and doesn't allow it to be knocked out dramatically one way or the other, for similar money, I'd probably go that route 🤷🏻‍♂️
Just me perhaps, and of course all hypothetical. Really didn't mean to stir the pot in any way, just searching for information.
5,023
It's just a discussion. No need to make it more than it is. :)
Dealership parts departments as a whole have to raise part costs or sell them at full retail to pay for dealership overhead. It's just the common scheme utilized by dealerships and why you have to pay more for servicing or repair work.
97% of the OEM parts I purchase, are from discounted parts dealers. They cut as much as 40% off the retail pricing.
Example; just purchased one Fuel Injector for a member; dealership cost was a whopping $125.00 per from the local dealership. MSRP cost $96.00. Hyundai Parts Deal $71.00 and if you shop around on the internet, as low as $63.00. So, in retrospect, there's a big margin the parts department charge due specifically to dealership overhead.
I appreciate the table discussion and thoughts. Most of the time, there are better scenarios to be found.:)
Reactions: jm1681
5,023
Check here for specs; :)
Chuckable
6
4
GA
Has anyone determined what the 2021 DCT models use for additional negative camber? I think the assumption is camber bolts, but it could also be the mount or knuckle. I can’t find any parts diagrams for 2021 models yet, but it’s an intriguing idea to use OEM parts to get additional negative camber on the manual cars.
