It's reasonable to say;
You've raised no awareness!
You've stated you've had an engine miss, now it's gone @ 2K miles You didn't bother to respond to any of the questions put to you, for a possible diagnosis or give any explanation. It's only happened to you and one other possibly. Yours has disappeared so, this leaves one person. What awareness have you raised?
I presumed nothing, only asked questions in order to help diagnosis a possible problem. Which
you chose to ignored and likely will again. At least I had the good sense to ask questions, in order to establish a baseline, for a some logical conclusions. Then offered up the simplest possible cause first.
The most likely problem is, the first as well as easiest too diagnosis. Try
Occam's Razor on for size: Another way of saying; it is that the more assumptions you have to make, the more unlikely an explanation.
OR
Occam's razor or the law of simplicity. Occam's Razor instead is saying is, that when presented with competing hypotheses that make the same predictions, one should select the solution
with the fewest assumptions and is not meant to filter out hypotheses that make different predictions.
There are members who own Veloster N's and haven't experience any of the same problems. You and the other individual are isolated cases, at best.
So the logical conclusion is the simplest; you gotten bad fuel, used to low an octane, have a fouled plug or..... You offered up nothing, nor did you take the time to diagnosis the issue at all. Did you use any logical or systematic diagnostic methods at all? Do you have a more simple or better explanation? By your own responses,
no.
So, you say in the first post,
"there's a problem and we could use more people talking about it, if it happens to you" and then you're attempting to stifle the discussion, you started. Oh brother, seriously!
And, the miss that you experienced, which was started by a crosspost from another forum, has magically disappeared
"poof," with no explanation.
Cygnus X-1; asked questions and made suggestions. Did you respond to his questions, attempt to utilize the suggestions or do anything he offered to diagnosis the issue?
Facts, don't care about your feelings. Neither do I. And I'm not going to argue with you, about your personal emotions or misunderstandings. Whew!
