Brakes Compatible Braided Brake Lines?
Apr 1, 2019
14
14
Ontario, Canada
Anyone know if there's any kits for braided brake lines out there for the Veloster N? Found a set for the i30N and figured the brakes should be identical, but no way to know for sure without comparing part numbers.
dacho
May 28, 2018
104
115
Croatia, Zagreb
II bought it from Forge for my I30N, and all is super except for the join on chassis I had to make a little improvisation (nothing terrible) and everything else was great, I immediately changed the brake oil and put the Motul RBF660
Apr 1, 2019
14
14
Ontario, Canada
What was the issue? fitting the bracket to the hub?
Also, is the brake feel noticeably increased?
Cygnus X-1
1,172
1,548
US
The Forge kit for the i30N should work fine, but nobody has tried it on a VN (yet).
In the meantime, switching to a racing DOT4 fluid will help a lot. Don’t get caught up in the DOT 5.1 hype... All of the best racing brake fluids are DOT4.
In case you’re wondering, the absolute best racing brake fluid available is Castrol React SRF. I like Red Line RL-600 as it’s reasonable in cost. Just make sure you get two 16-16.9 oz. bottles and fully flush the OEM garbage completely out.
While having a high dry boiling point is great, even more important is the wet boiling point, since water content increases in fluid over time. Pick a fluid that has a wet boiling point of close to 400°F or higher.
dacho
May 28, 2018
104
115
Croatia, Zagreb
The problem was here, the shape is not the same as the original, soo a plastic cable tie solve the problem :cool:
I know for Castrol SRF I use it when I was racing, but for road and track day car Motul is just fine, I use 1,5l for full flush the system ;)
Apr 1, 2019
14
14
Ontario, Canada
Yeah, its a matter of time before people start trying stuff, someone has to be the first person, right?
Good point about wet boiling temp. Ill try it out this summer at a few track days and autocross and probably swap it out midway through after I've used the car a few times (still snow and ice here until just yesterday)
Cygnus X-1
1,172
1,548
US
I meant you should change the fluid now and see if that’s enough to satisfy you, before getting a line kit. I swapped it out and feel no need to get lines at all, meaning funds can go towards other things the car needs.
Apr 1, 2019
14
14
Ontario, Canada
Ok so nothing too bad fitment wise. Good to know!
Since you and Cygnus both mentioned Castrol SRF ill definitely look into it.
Apr 1, 2019
14
14
Ontario, Canada
Yeah, honestly I haven't even had a chance to push the car and see how it feels, but I just know brake fluid will most likely be one of the things I need to do.
Yeah exactly, save myself at least 250$ Canadian + whatever duty on top of that.
Who! Me.
Apr 4, 2018
412
186
Belfast
If I decide to change the brake lines does the whole system need to be re blead or only the line or brake side I’m working on.
without
365
349
Does depend on the brake fluid. If yours is still good and you add the same as before (some can even be mixed), you can just top it up. Some „better“ brake fluids are not supposed to be mixed with others.
That being a aid, I would drain it entirely anyway.
