No oil pan baffles in any Hyundai engine.
Oil pan baffling is not required for track day racing in the US. I'm not sure about European track day rules but I wouldn't think so.
You'll find it hard to dry sump or oil starve, the oil pump on any transverse 4-cylinder. The only way it might happen is if you've under-filled by 2 quarts. Additionally, you're not moving oil around enough in the pan to cause a problem. Keeping in mind, it's viscous. You're not moving with enough force to cause this problem.
