Auto-lock when walking away from i30N
The_Sentinel
21
Australia
Hi folks.
Reading through the general threads seems to indicate this is an option.
I thought I'd ask here though as there are quite a few features that are enabled dependent on your locale.
My current car (Mazda) will automatically lock when the keyfob is more than a couple metres away from the car.
i.e. you walk away from the car.
I did have to have this function enabled by the dealer in the Mazda.
For those that have their new cars already, is auto-lock this something that the 2021 I30N does by default (or can be requested turned on by the dealer)?
Note that I'm not referring to auto-lock when the car is unlocked but locks again if the doors haven't been opened for a period of time.
Reactions: HJM2001
asdf144
66
49
Hi folks.
As far as i know thats Not an option and was never any? AT least its Not in the fl :/
Hugh_85
151
188
SE QLD, Australia
Only auto lock I have is if I unlock the car but don't open any doors within 60 seconds.. My 2003 Landcruiser has the same 'feature'. Doubt a dealer would turn any auto-locking feature on since they won't do the window control by fob now either.
sgfastback
104
115
Sydney
I don't think I would trust an auto lock feature. even if it was available. There is no way I would walk away from the car without looking back to see if the mirrors had folded in. In which case, I would rather manually lock the car and know for sure that it is locked šŸ˜€
HJM2001
5
I would like to have this function in my keyless i30 Premium DCT!
So if i come to the car, it would be great to open the central door locking, as the mirrors fold out. So you dont have to push the button on the door handle. Also it would be great to go away and the car locks automatically, because sometimes it seems that i forgot to push the button.... :confused:
As i see in the function description on https://mykeypremium.com or https://www.12volt.solutions, they both offers the remote start kit with the function to open and close the door via keyless entry, without push the button! Thats the option i want to have, but the German i30 keyless entry seems to have other connectors as the USA Model of the elantra GT 2019.
The good thing is that you have just to clip out the connectors on the right side under the glove box and connect the T-Harness and thats it. Only 5 minutes work to do, the unit and the harness can be fixed behind the right cover and the carpet. And on top its possible to remote start the engine, if you have a DCT. Great!
Attached you can see the position of the three Connectors in my car, seems to be the same as in the i30N, i30 keyless entry and i30N keyless entry.
The_Sentinel
21
Australia
As mentioned above, I have this on the Mazda. Not really a drama as the lights flash and you get the lock "beep" sound when you walk more than 2 metres away from the car with the keyfob. You just have to listen for the sound.
HJM2001
5
I ordered the Proximity Smart Door Lock Module from THIS side. Only 4 cables to fix, +12 V, Ground and Can-H, Can-L. So its not a problem and done within 5 Minutes. The next step is the remote start kit. Hope to get it in 2-4 weeks. *Remote Start*
The_Sentinel
21
Australia
That's awesome. I had a similar mod on my Astra years go to auto-wind the windows up. I thought there may have been some after-market mod to do this on the i30s but didn't find anything after extensive Googling.
Which instruction manual did you request from your supplier when you ordered?
I'm presuming the Elantra or Elantra Sport??
asdf144
66
49
Autowind the Windows up? You mean automatically šŸ¤” without you Holding the close Button on your smart key?
The_Sentinel
21
Australia
On the Astra, when you locked the car from the key, it would automatically wind all the windows up.
Smartkey just had a lock and unlock, no close button.
When you locked the car (i.e. the hazard lights flashed when it locked), up they went.
asdf144
66
49
Just hold the close Button for a bit longer and i30n will Do that too?
HJM2001
5
They talked about automation of this process, so you wouldnt forget it (or if you dont know that the windows are open).
NULLOBANDITO
1,667
2,264
Innsbruck, Austria
I'm not sure if it's programmable anymore. I had windows up/down with the lock/unlock button programmed but with more recent cars they took away some of that functionality from what I recall.
